Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Message posted on 21 Jul 2024 06:37 PM
Re: Netflix
Are you seeing a red spinning circle @Janey081 ?
Message posted on 21 Jul 2024 06:38 PM
Re: Netflix
Yes. I have the Netflix logo and a spinning circle
Message posted on 21 Jul 2024 06:41 PM
Re: Netflix
I've moved your post into the large thread discussing this issue that some customers are experiencing. See the post currently marked as the answer (post 2) and other possible temporary fixes.
Message posted on 21 Jul 2024 06:55 PM
Re: Netflix: Red Spinning Circle on Launch
@PETROS+PETRA wrote:@Anonymous
Forgive me - I should have replie to you.
Forgive me - I am getting confused.
- Log into Netflix via the web browser.
- Highlight your profile picture (Top right corner).
- Click on Account.
- Under the Security and Privacy option, click on 'Manage access and devices'.
- Select the device name: (it may be called SkyQ ......or Sky UK Set-top box).
- Select--> click on the "Sign out" option on the SkyQ ......or Sky UK Set-top box.
- Sign out of Neflix on the Q box, start it up, press left and go to the help section to sign out.
- Reboot SkyQ box by turning off at the wall or plugging out for 1 minute.
- Go to your SkyQ box and launch the Netflix app on your SkyQ box.
I see there are 9 points not 8. I have done points 8 & 9.only and that seems to give a temporary fix. I have not done 1-6 and I cannot do 7 because I cannot sign out of Netflix on my Q box. If I could do point 7 there would not be a problem.
Ignore point 7 then but you have to do 1 to 6 and 8 & 9
If it's easier for you, points 1 to 6 amount to the following:-
Go to your account online through a browser and sign in if necessary, from your portrait/avatar, go to 'Account', then 'Devices', then 'Access and Devices' and then sign out of all Sky devices listed.
The direct web address is:- netflix.com/manageaccountaccess which can be copy & pasted into your browser.
Don't forget to reboot the Q box last.
Message posted on 21 Jul 2024 07:03 PM
@Anonymous
Thanks. I am giving this forum a break for a while - it is taking up too much of my time. I will just have to watch Netflix from my mini-box in the bedroom! That is working.
Message posted on 21 Jul 2024 07:26 PM
Why can't you go here to do points 1-7:
Message posted on 21 Jul 2024 10:10 PM
Re: Is anyone having problems with netflix
I've been trying to get on to Netflix'sApp for 3 days now on my tv through Sky and it just shows the Netflix logo and the circle going round and round and just not loading . I've tried unplugging my sky box but that didn't work . I trot on my phone and it's ok , I've tried signing out as the trouble shooting said but that also didn't work.
please help.
Message posted on 22 Jul 2024 05:39 AM
Give this a try:
Message posted on 22 Jul 2024 08:23 AM
Thanks. I tried this and it worked. Is this a permanent fix or will I have to keep doing this?
Message posted on 22 Jul 2024 09:35 AM - last edited: 22 Jul 2024 09:37 AM
That should be permanent as the problem (I think) was an authorization token that had expired and you've now started afresh. For some reason the Q box wasn't deleting or updating the old one properly. I suspect the 270 software upgrade for Q boxes being rolled out now will have a fix to stop it happening in the future and maybe to resolve it for people affected now.
The above is all just my guess BTW.
Edit: I have seen one or perhaps two people claim this hasn't worked for them but I highly suspect user error in doing the fix.
Message posted on 22 Jul 2024 10:33 AM
Netflix has just still working for no apparent reason. Following all the on screen help menus.
Message posted on 22 Jul 2024 10:48 AM
@Anonymous
Very many thanks.
Message posted on 22 Jul 2024 11:09 AM
Thanks for the uodate. Our box still frequently has this problem and I've never previously logged it, so I'll complete the form.
Is there a link that explains how to go through the fixes step by step?
Many thanks
Message posted on 22 Jul 2024 11:28 AM
Re: Netflix has just still working for no apparent reason. Following all the on screen help menus.
@Lee19681 wrote:
Tried all the troubleshooters on the box and it just keeps bringing up the logo and the circle keeps going around...
Which box? Sky Q? Or Sky Stream?
Message posted on 22 Jul 2024 11:33 AM
