2507
This discussion topic is read only This discussion topic has been answered Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Locked
This message was authored by: alan.pres
Re: Netflix: Red Spinning Circle on Launch
Try the solution by Colin0000 it worked for me.
This message was authored by: Biggarscotland1
My Netflix won’t load
My Netflix won't move off red spinning stage I have reset box and turned off and on and still the same this has happened for the last 2 weeks
Re: My Netflix won’t load
@Biggarscotland1
I've moved your post into a large thread discussing this issue. See post 2 currently showing as the answer.
This message was authored by: PETROS+PETRA
@Biggarscotland1
Exactly same problem
@Laurss6 @PETROS+PETRA @Biggarscotland1 @Feathers
This is the fix that is working for others:
https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/m-p/4691069/highlight/true#...
This message was authored by: Anita2305
Netflix won’t load. Netflix say it’s sky issue
Netflix won't load. According to Netflix they have done an upgrade and sky need to put upgrade thru. Totally confused. I just get the swirling circle
Re: Netflix won’t load. Netflix say it’s sky issue
@Anita2305
Your post has been moved to the large thread already discussing this.
This message was authored by: Jemma+A
Cannot get into netfix
Netflix it's loading it just keeps circling and doesn't load been like this for over 2 weeks
This message was authored by: Chuck
Re: Netflix not moving from spinning red circle
I've done this many times ... Sky then said I had signal problems that took 3 visits to get download speed which solved nothing ... Sky have no answer to the ongoing problems with Netflix customer problems ... (Removed)
Moderator note: Removed campaigning comment
This message was authored by: Dr+DJ
Cannot access netflix, most days not, occasionally can
when i try to access netflix, get the logo screen and a spinning circle. Most daysget this, occasionaly can access, therefore intermittent error. Can any clever soul diagnose?
This message was authored by: Feathers
@Pg666 @Thank you
Re: Cannot get into netfix
As this is a Sky Q issue @Jemma+A I have moved your post to the Sky Q forum as this fix has been posted so do give this a try:
You can let Sky know about this via this form - https://forms.office.com/e/VGr0tUpv67
@Anita2305
To fix it you need to do this:
This message was authored by: CornwallD
Trying to sign into Netflix via web browser but doesn't recognize our email. Never had a Netflix account before it's part of the Sky package. Like for many it worked fine for ages now spinning red circle. Re booting occasionally works but inconsistent
Use the online Netflix password reset and try your Sky ID email, in fact try all emails you may have. Mine for instance is actually the sons as it was originally his Netflix account. If it is your Sky ID email and you've never signed in online then you need to do this in order to setup a Netflix online password.
Locked
Answered - Go to Answer
