Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Message posted on 18 Jul 2024 01:24 PM
Re: Netflix: Red Spinning Circle on Launch
After weeks of frustration I loaded Amazon Prime then Netflix and it worked!, I tried before loading BBC iPlayer but that didn't work. Hopefully it will work again when I actually want to watch it.
Message posted on 18 Jul 2024 01:26 PM
Re: Cannot login into Netflix but can on other devices including smart TV
Are you seeing the spinning red circle ?
@JAG1948 wrote:After weeks of frustration I loaded Amazon Prime then Netflix and it worked!, I tried before loading BBC iPlayer but that didn't work. Hopefully it will work again when I actually want to watch it.
Just follow the post linked above yours, loading other apps seems to be only temporary.
Message posted on 18 Jul 2024 01:43 PM
Hi, yes there is a spinning red circle under the work Netflix but nothing happens
Message posted on 18 Jul 2024 01:56 PM
Did you try this
Message posted on 18 Jul 2024 02:28 PM
Netflix not loading
Message posted on 18 Jul 2024 04:11 PM
Re: Netflix not loading
If you are seeing the red spinning circle then doing this should fix it:
Message posted on 18 Jul 2024 04:54 PM
Thank you, I will try when I get home. Cheers.
Message posted on 18 Jul 2024 05:15 PM
I'm experiencing the spinning circle on the mini box in our kitchen. The main box in the lounge took a little while but did load eventually.
I've filled out the form.
Message posted on 18 Jul 2024 05:36 PM
Re: Netflix app
@Bwanarayiris wrote:
So, tried Netflix app on minibox in another room, loaded up no problem, still not loading on main box, sky q, all other apps working fine
@Bwanarayiris if you are getting the spinning red circle
look at the thread below and post marked as the answer this gives you a form to complete for Sky
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 18 Jul 2024 05:37 PM
Re: Netflix not working for ages
@Pompeydave1 wrote:
I've had nothing but trouble with Netflix loading for weeks. Router on / off , sky box on / off , opened all apps ,0 0 1 refreshed apps etc etc.
Been pulling my hair out so yesterday tried 0 0 1 on settings and did the lowest reset settings.
Surprise , surprise Netflix now instantly loading.i lost my favourites (channels) so had to save them all again and remote had to be reset using keys 7+9 together then 1+3 together to marry up with box. Also all apps temporarily disappeared but then reappeared minutes later.
But now system seems quicker and Netflix loading instantly. Fingers crossed it lasts but at least I know it works.
@Pompeydave1 see te post by @caesarome marked as the answer
Message posted on 18 Jul 2024 08:14 PM
Right, I couldn't do step 7. Signed in on laptop, signed out of all devices, restarted main Sky Q box and upstairs mini box that had failed, started Netflix on tv upstairs and was working again. Think as long as you sign out of all devices and restart your Sky Q boxes you should be good. Fingers crossed 🤞. Good luck.
Message posted on 18 Jul 2024 08:41 PM
Can sky block signal of Netflix as I pay Netflix direct and now not working.
Since last week I have been unable to access Netflix from tv in bedroom through apps. All other apps are working apart from this. Same in main sky Q box however can get in through Netflix on tv screen as new tv but tv in bedroom does not have this option as a couple of years old.
raging at sky as spent the best part of an hour on phone with them updating system/tv and apps for them to offer me it through sky. I feel they are deliberately blocking or scrambling signal as I pay this direct to Netflix and not sky.
Any advice appreciated
Message posted on 18 Jul 2024 08:43 PM
Re: Can sky block signal of Netflix as I pay Netflix direct and now not working.
Are you seeing a red spinning circle?
Message posted on 18 Jul 2024 08:45 PM
Yes. Sane if i try in livingroom but can go in through other route on this tv
