2507
This discussion topic is read only This discussion topic has been answered Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Locked
This message was authored by: Heather57
Re: Netflix: Red Spinning Circle on Launch
I've spoken to sky they are aware of the issue and Netflix are trying to solve it now
This message was authored by: Stuart6641
Netflix issue
Netflix app wont start, red circle keeps going round. This happens on Main unit not on one in bedroom which is ok. Tried resets already and still unable to use.
Re: Netflix issue
Likewise @Stuart6641
Your post has been merged with a thread on the Netflix issue some customers are experiencing. See the post currently marked as the answer.
This message was authored by: Pg666
Re: Netflix issue
Hi. There was an earlier answer (from Sam999 I believe) on this that seems to work for most of us. I recommend you try signing in to Netflix thru a laptop or mobile Ie not Sky then try the following
If you cannot log into Netflix through SkyQ box:
1 - Log into Netflix via a web browser.
2 - Highlight your profile picture (Top right corner).
3 - Click on Account.
4 - Under the Security and Privacy option, click on Manage access and devices.
5 - Select the device name: (Sky UK Set-top box).
6 - Click on the "Sign out" option on the Sky UK Set-top box.
7 - Go to your SkyQ box and perform a complete power cycle on the SkyQ box (not just on standby mode)
8 - Launch the Netflix app on your SkyQ box.
If you manage to log into Netflix on the SkyQ box:
1 - While you are in your Netflix profile on the SkyQ box, scroll down and on the right hand corner and click on/select the 'Get Help'option.
2 -
Sign out of Netflix.
3 -
Sign back into Netflix (with your email address and password for your Sky Subcription if you don't have a separate subscription for Netflix). Alternatively, sign in with your Netflix credentials if you have a separate Netflix subscription.
4 -
Power cycle (on and off) your SkyQ box. Make sure the power is completely out (not just on standy mode)
This message was authored by: Kashif4
Re: Kashif
Yes, its the unending circle.
This message was authored by: BennyG1
We have had this now for months. It almost definitely doesn't load but once in every 15 attempts it might. Ridiculous. Why can't this be fixed? It's clearly a major problem.
This message was authored by: carol106
Re: Netflix on skyq wont load works on all over devices and tvs tried retarting skyq box several tim
just set up sky broadband a few hours ago.  cant get apps auch as netflix as they wont download
Re: Kashif
2 -
3 -
4 -
This message was authored by: Ck100
Netflix will not load on my Sky‘s mini box
My son has a sky mini box in his room and Netflix takes ages to load sometimes over an hour before Netflix works. He has good connection with the Wi-Fi.
Re: Netflix will not load on my Sky‘s mini box
@Ck100
Is he / are you seeing a red spinning circle?
This message was authored by: Bubbledogg1
This is still an issue and the workaround is a farce sometimes works othertimes doesnt , plus i dont want to have to take 10 minutes rebooting sky everytime i want to watch netflix .
So many issues like this with sky , we pay a premium for this service sort it out sky and think of your customers for a change
This message was authored by: MURTALBOY
App not working
Netflix not working
Netflix not working
Yes, the circle spins for ages and ages and just won't load
This message was authored by: Redskull
Having issues with netflix for 2 days. Nothing seems to work......
@Ck100
I've merged your post into a thread discussing this issue that some customers are experiencing. See the post currently marked as the answer (post 2).
Locked
Answered - Go to Answer
