2507
This discussion topic is read only This discussion topic has been answered Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Locked
This message was authored by: BaileyGB
Re: My Netflix isn’t working
@Lorrsine wrote:
On my tv. Circle just keeps turning. Everything else seems fine
Please read posts above yours....you answer will be there
This message was authored by: Martin144
Netflix
Netflix will not load. The Netflix logo appears but the red loading circle just keeps turning and it won't load.
Re: Netflix
@Martin144
I've moved your post to a thread already discussing this issue. Please see the post currently marked as the answer.
This message was authored by: Ruby27
Netflix not opening
My Netflix app won't open it hasn't done now for over a week, sometimes it did open on and off this is the longest it has not worked it is part of my package with sky
Re: Netflix not opening
@Ruby27
I have moved your post to here where this issue is being discussed at length, the post marked as the answer from Sky says this is a known issue that will be fixed in a future software update.
This message was authored by: swhxd06
Re: Netflix: Red Spinning Circle on Launch
Well I know I'm tempting fate, but mine appears to be working completely normally again. Could this mean that I've had the update? Only time will tell 🤞
This message was authored by: AnnaMarie
Netflix is not coming on just the red circle continues to go round but won't come on to work
Netflix is not working for past number of days even if we reset sky q etc nothing it's the only app not working continues to just show Netflix icon that's it
This message was authored by: Malev123
Re: Netflix is not coming on just the red circle continues to go round but won't come on to work
My Netflix is doing the same
This message was authored by: lifeat39
Re: My Netflix is not loading on my main Sky Q box
Hi all, Ive tried everthing and still daily issues loading Netflix through Sky Q Box. SKY GET THIS SORTED, ABSOLUTELY REDICULOUS !!!!
"Ridiculous"
@lifeat39
It appears you haven't seen the post currently showing as the answer (post 2).
Yeah that sounds odd that the independent sub would be cheaper. Must be the SD version or with ads or both.
I think they mean cheaper without having to pay a Sky sub, as a sort of veiled threat, sort it or else?
This message was authored by: Cc99
Netflix will not load red spinning wheel. Loads fine on mobile.
only happening on sky. Reset router/ tv/sky box still won't load
Re: Netflix will not load
@Cc99
I have moved your post to here where this is being discussed at length so this is the latest from Sky:
https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/m-p/4666628/highlight/true#...
Locked
Answered - Go to Answer
