Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Message posted on 06 Feb 2024 06:55 PM
Re: Netflix Won't Load / Spinning Circle
Not everyone has a smart TV with their minibox so I'll have to carry on being annoyed.
Message posted on 06 Feb 2024 07:15 PM
@El+Arid wrote:Not everyone has a smart TV with their minibox so I'll have to carry on being annoyed.
Or get a firestick
Message posted on 07 Feb 2024 07:57 PM
Re: Netflix often not working on SkyQ
So, we get this most of the time:
- Netflix opens, the Netflix logo appears but the red spinning loading circle appears.
It's really frustrating and rebooting the router and sky box no longer resolve it. Come on Sky - please sort this out!!!
Message posted on 07 Feb 2024 09:07 PM
@judotom wrote:So, we get this most of the time:
And have you tried the other suggested workaround in the post marked as an answer?
Message posted on 13 Feb 2024 08:39 AM
I am trying to message you, but it says my message contains bad language (which it CERTAINLY does not).
How else can I get you the information?
Steve (& Jane)
Message posted on 13 Feb 2024 09:19 AM
@SteveandJane wrote:I am trying to message you, but it says my message contains bad language (which it CERTAINLY does not).
Steve (& Jane)
Message who exactly and how (on this forum)?
Without giving out any personal information what are you looking for help with?
Message posted on 13 Feb 2024 02:25 PM
@Chodley Apologies - was meant for @Chloe-W22 !!
Message posted on 13 Feb 2024 02:59 PM
Still having these issues (started to affect the other multi room box's now). Have done all the fix's mentioned but the issue (at least for me) returns again and again.
Yesterday, we had to re-aquire AppleTV+ as it had logged us out and we had to scan the code, input a code and everythign to get the service back. If this is whats required to properly get netflix to start working then why dont they initiate a reset like this, so everyone would need to re-enter the log-in stuff via scanning the code and entering the code all over again.
Just to iterate yes i have done sams fix 2x. first time it last about 5 days before returning but i did not log into netflix for 2-3 days. 2nd time it last for 2 days (3 netflix log-in attempts roughly) before it came back. I found it easier to just spam logging in or log out and log into another app then out and try netflix again. This so far has been the easiest to do. But right now there isnt much to watch on netflix anyways
Message posted on 13 Feb 2024 06:12 PM
Heh, that solves the problem
but if you haven't watched the Dark Crystal, you need to 🙂
Message posted on 13 Feb 2024 08:37 PM
The answer that involves logging on to Netflix via a browser and then removing the sky box from the devices list works, but doesn't last very long before it needs doing again. It is at least a way around things until the Software Engineers figure out a solution.
Message posted on 16 Feb 2024 08:25 PM
Re: Netflix not loading
I am having the same problem also. Every day I have to switch off and on. It can't be Netflix as it works ok on my sky mini box and straight onto the TV.
Message posted on 17 Feb 2024 04:08 PM
Try exiting Netflix with the Netflix menu (far left at the bottom) as opposed to the remote home button, works fine for me then on the next selection.
Message posted on 17 Feb 2024 08:34 PM
@Chloe-W22 the option signing out of the Sky Q box on my Netflix login in a web browser worked brilliantly, and I've not had the issue since. I did this about 6 or so weeks ago!
Previously, it was more often than not getting the spinning circle, unless I refreshed the app and it then worked for a little while after a couple of hours.
Message posted on 17 Feb 2024 08:36 PM
@CGJB wrote:@Chloe-W22 the option signing out of the Sky Q box on my Netflix login in a web browser worked brilliantly, and I've not had the issue since. I did this about 6 or so weeks ago!
This fix also worked for me and seems to be a permanent repair
Message posted on 18 Feb 2024 12:46 PM
Netflix not working on SkyQ
Sky Q serial no. Is 0627505284D
netflix ran = Skuskyhqw=00000000000000001000000004098332 can you help.
Netflix works on tv app
