2507
Discussion topic: Netflix has encountered an error. Code: tvq-st-102
This message was authored by HalcyonDays This message was authored by: HalcyonDays
Re: Netflix often not working on SkyQ
Red circle comes and goes.still. Details as sent as requested to Chloe Sky Emoployee who hopefully will solve this continuing issue
This message was authored by AndreaBenner This message was authored by: AndreaBenner
Re: Netflix Won't Load / Spinning Circle
Update - Just tried to access.. I spoke too soon..!! RED CIRCLE OF DEATH IS BACK!!
Nice whilst it lasted..  Sad times..  😞
This message was authored by lad13 This message was authored by: lad13
Hi - tried the workarounds and not currently working.
netflix SKUSKYFD1=00000000000010000000000734931
seriel number 0488853841C
let me know if you need any other info. Thx
This message was authored by Chodley This message was authored by: Chodley
And did you try the suggested solutions in her post?
Not yet as I was busy so didn't get time.. But I will do..  Thanks..  😀
This message was authored by melll1972 This message was authored by: melll1972
I tried the solution in Sam's post as well as the answer provided.  No avail, still got the red circle.
could we have an update on a solution rather than a workaround?  Looks to be app issue.  Getting similar with paramount, yet Disney, Prime and YouTube are all fine.
very frustrating.
This message was authored by BaileyGB This message was authored by: BaileyGB
very frustrating.
Sam's post was a solution for many people.
I had to turn off the box from the plug and restart the Q box and now able to get in to Netflix
This message was authored by Sue014 This message was authored by: Sue014
Hi @Chloe-W22 , I am getting the same red spinning circle on Netflix as well. I turn the power off, use the 001 code via settings to refresh the apps, it works for a short time and then it happens again, it does not load.
This message was authored by Anonymous This message was authored by: Anonymous
Try Sam's fix, it works more reliably than any others.
Rather helpfully, it's working now.  Didn't need to do anything other than wait overnight.  Netflix came up with a fresh sign in (after Sam's attempted workaround), but it's working for the time being.
Sorry, can you explain that again. You did nothing and it started working after waiting overnight but you also did the signout workaround?
This message was authored by Zeus2006 This message was authored by: Zeus2006
Netflix red circle still going round after I've done an app update it is making watching anything a real problem and costing monthly but not able to watch anything
Try the suggestions at:-
https://helpforum.sky.com/t5/Sky-Q/Netflix-often-not-working-on-SkyQ/m-p/4516173/highlight/true#M621...
This message was authored by Gerry2021 This message was authored by: Gerry2021
Re: Netflix Stuck Spinning Circle
Hi,
I have had the same problem, Netflix N and the spinning wheel. I have disconnect my Q box, a month ago this worked a few times for a while then same again, spinning wheel. Recently I had a visit from a Sky engineer - network issues that were resolved. She completly reset and rebooted my router.  All good for a few days then same problem again. So quick fix - disconnected the Q box and sometines the next day it works, for a while then back to the spinning wheel.
I have now found out from this forum how to refresh the app and done so. No joy still the spinning wheel.
So went back and refreshed the apps again, then when it was finished, I disconnected the Qbox - waited 30 seconds and then restarted. And after a few moments the spinning wheel stopped, then started again and then Netflix started properly. So going to check if this is a lasting fix  and come back to this forum.
