Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Message posted on 13 Nov 2023 09:02 AM - last edited: 13 Nov 2023 09:25 AM
Re: Netflix app crashing/won't load
@AdamW77 wrote:Well, the suggestion worked for a while.
However we have just sat down to watch a film. It played 20 seconds and then the app crashed and it went back to sky. Now....will not load again
Well that at least is new although of no help to you. Have you tried plugging the box out for 60 seconds?
Message posted on 13 Nov 2023 09:14 AM
Colin,
What was it you actually did to resolve your issue? I'm happy to try anything to solve my problem.
Message posted on 13 Nov 2023 09:24 AM
@BaileyGB wrote:Colin,
I'm uncertain what exactly helped with mine but have you tried Kirsty's suggestion on the first page (the "answer") first off? "Test Participation" off.
I have my Q box hardwired to the router with no mini boxes so I turned off the WiFi from settings (the hidden settings option).
I have had to turn the box off 3 times (I think) since mine was resolved but for recordings issues, I've had no issues with Netflix since June I believe it was. I was using the the built in SmartTV App for awhile before that myself.
Message posted on 13 Nov 2023 09:34 AM
I'll give that a try Colin, thanks. I do have a mini box which NETFLIX works with no issues. It's the main box where I have the issue.
Thanks again
Message posted on 13 Nov 2023 10:31 AM
@Anonymous yes, I did unplug the box for longer than 60 seconds. Unfortunately this makes no difference. I did switch off the test participation, which instantly got Netflix up and running, but only for a short period. My boxes are hard wired, so wifi is completely off. I did log in to Netflix website again and sign out of the sky boxes. This made no difference either as it just won't get as far as a log in page. Again, this is only on the main box. All 3 mini boxes work perfectly.
Message posted on 13 Nov 2023 11:22 AM
Re: Netflix sporadically not loading
I have the same problem, Netflix just hangs on the logo screen, with over 6000+ views on this topic lets hope somebody at Sky / Netflix are monitoring.
Message posted on 13 Nov 2023 06:17 PM
Can’t get my Netflix
My Netflix isn't working it's just froze and circling.
Message posted on 13 Nov 2023 06:34 PM
Re: Can’t get my Netflix
Have you tried a Q box reboot @Suzan1
Message posted on 13 Nov 2023 07:52 PM
My Netfilx was working perfectly OK yesterday and today I updated to fibre and now I also just have the spinning circle.
Message posted on 13 Nov 2023 08:18 PM
@Dave6516 wrote:My Netfilx was working perfectly OK yesterday and today I updated to fibre and now I also just have the spinning circle.
Are you using WiFi? If so, then can you try a wired connection and turn off WiFi on the Q box in the hidden settings?
How to access the Sky Q hidden engineers menu
Please follow the below instructions in quick succession with no breaks between steps.
- Press the ‘Home’ button on your remote control.
- Scroll down to ‘Settings’ and DO NOT press select.
- Press ‘001’.
- Press ‘Select’
Message posted on 13 Nov 2023 09:05 PM
I have sussed out what the problem is. Well for me it works. Only hassle you have to turn the tv and sky on seperatly.
go into settings/setup/Audio visual and switch off HDMI control
Sky you can pay me if you want!!
Message posted on 13 Nov 2023 09:28 PM
Message posted on 13 Nov 2023 09:49 PM
My problem also started once I had an upgrade to fibre as well so the problem definitely lies with sky fiber Internet, I am sure of it. I have had it for the last 9 years without ever having a problem with it until July when I upgraded.
Message posted on 13 Nov 2023 09:52 PM
Sorry......
I have the problem but do not not have fibre!!!
Message posted on 13 Nov 2023 09:53 PM
Will definitely be trying this out & if it works great 👍
