2507
This discussion topic is read only This discussion topic has been answered Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Locked
This message was authored by: Bobafet
Re: Netflix sporadically not loading
This is alright if you can get that far. My Netflix on the main box will not load past the main Logo screen. No options, no nothing.
This message was authored by: BaileyGB
Mines exactly the same..... ridiculous!! Been going on for ages now!!!!
Re: Netflix on sky q will not load
@Superbad wrote:
Do you do this while Netflix is trying to load or on the Home Screen? Is the back button the menu backup button or the rewind, I've tried all combinations. Thanks.
Surely a sky engineer should be commenting on this.
Yourself and @mrpskm have failed to quote anyone so it's not clear what you are trying to do?
There is only the one 'back' button on a Sky remote.
Why would a Sky 'engineer' comment on it?
This message was authored by: mrpskm
@Anonymous There two the rewinnd and the button the takes you back
This message was authored by: Geezert
Re: Netflix app does not load on main box
The issue has started again, both main and mini box are running the same software version but Netflix loading on the main box is still an issue but not the mini box.
Anyone got any ideas please?
Hi @Geezert
Have you tried a Reset Settings in the Q box hidden menu.
This message was authored by: Katie52
We have Netflix through sky and keep getting the same problem 😞
Maybe they mean a Sky software engineer..
Yes, perhaps you're correct but that's even less likely. Surely people want them solving issues rather than waste time on the forum?
The rewind button does seem to work but only in certain circumstances (that was actually news to me as I've just tried it 🙂 )
Use the arrow keys for moving around and going back or just use the exit button and start again.
This message was authored by: Leanne2023
  • I'm also having this issue an I pay Netflix through my subscription so annoying
This message was authored by: Elaine641
My Netflix is not loading on my main Sky Q box
My Netflix is not loading in my main TV on the sky Q box
Re: My Netflix is not loading on my main Sky Q box
Hi @Elaine641
 Check the Software version on your Q box
Home - settings - System info - Software version
 https://www.sky.com/help/articles/sky-software-updates
if it is not update it.
Home - settings - System info - Highlght Software version and then select Setup and then select Update this box with latest Software.
This message was authored by: d401
I have updated my software as suggested and my Netflix is still not working on my sky q box. Any other suggestions?
This message was authored by: team+bobbins
Yeah I have the same issue. I don't want to have to unplug my sky box every time I want to watch Netflix. That fact I am paying for something I am not getting is not acceptable.
Locked
Answered - Go to Answer
