2507
This discussion topic is read only This discussion topic has been answered Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Locked
Re: Netflix: Red Spinning Circle on Launch
@Daniel0210 wrote:
@Dawn+hazell
Your first post has been answered above.
And her first post is right beneath my post which explains how to resolve it...
This message was authored by: Markymarr
Re: Netflix won’t load, I’ve tried refresh
Netflix is not loading as just red dot spinning,I have unplugged my Q box and left it a minute but no joy
This message was authored by: WB1760
I am having the same problem. Updated software but still seeing only the red spinning circle. This seems to be a common problem but I can't find a resolution
@Markymarr @WB1760
I've merged your posts into the main thread discussing this issue that some customers are experiencing. See the post currently marked as the answer (post 2) and other possible temporary fixes.
@WB1760 @Markymarr
Have you seen this link as this is what you both need to do:
https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/m-p/4691069/highlight/true#...
This message was authored by: Dawn+123
my netflix won’t come on it just keeps spinning
netflix won't come on it just keeps spinning
@Dawn+123
I've merged your posts into the main thread discussing this issue that some customers are experiencing. See the post currently marked as the answer (post 2) and other possible temporary fixes including the one posted by @caesarome immediately above your post.
This message was authored by: Cutdown
well thats a hour out of my life i wont get back and still netfkix dont work , thats a month iv paid for nothing
This message was authored by: Leeeeeetttt
Well you won't get any of the hours of your life back , no matter how good they were
Re: my netflix won’t come on it just keeps spinning
And that's the third time you've said so, have you not read any replies whatsoever?
This message was authored by: AnthonyP56
Re: Netflix on sky q will not load
Hi , I've experienced the same problem with Netflix failing to load over the past few weeks . I cured it today , not sure which bit actually worked , but I did the following ... signed out of Netflix and back in , deleted all the saved recordings in my Skybox then refreshed all my Apps via the ' secret page ' in the Sky menu ( Google it , it's easy to find ) . Netflix didn't work immediately , but after a few hours . I'd already done the unplugging re set thing a couple of day's ago , which didn't work . My guess would be , there was too much stored in the memory ( recordings ) , so the combination of deleting all that , then refreshing all Apps did the trick .
@Cutdown
Did you follow the instructions given step by step, if you can't access Netflix to logout make sure you do it via the Netflix website instead.
This message was authored by: Andy00
Netflix app stuck on load page
Netflix app stuck on load page. Spinning circle.  All others ok. Tried reboot and things suggested off you tube to no avail. This happened same day as computer outage.
Re: Netflix app stuck on load page
@Andy00
I've moved your post into a very log thread discussing this issue. Please see post 2 currently marked as the answer and also this
This message was authored by: Mick90
Netflix app wont load comes up with the Netflix logo and red circle just spinning
Netflix logo appears when you go in to apps on sky q and red circle spinning but will not do anything else it works on tablet and phone so it's got to do with the sky box
Locked
Answered - Go to Answer
