21 Jul 2024 01:08 PM
Posted by a Superuser, not a Sky employee. Find out moreWhat's happening when you try to launch?
21 Jul 2024 01:09 PM
The red circle just keeps spinning but not loading
21 Jul 2024 01:11 PM
Posted by a Superuser, not a Sky employee. Find out moreI've moved your post into the large thread discussing this issue that some customers are experiencing. See the post currently marked as the answer (post 2) and other possible temporary fixes.
21 Jul 2024 01:57 PM
This is what you need to do @RaySavill
21 Jul 2024 03:04 PM
I have two mini box sky q. One box will not load Netflix , just than annoying circle going round. Sky so difficult to contact any suggestions please. I really can't wait to get rid of sky
21 Jul 2024 03:05 PM
Posted by a Superuser, not a Sky employee. Find out moreI've moved your post into the thread discussing this issue. See the post currently marked as the answer (post 2) and other possible temporary fixes.
21 Jul 2024 04:10 PM
Hi. Yesterday (20th July) all was working well and I thought the problem had been solved. Alas, no the problem is back today (21st July).
Sofrustrating
21 Jul 2024 04:17 PM
Posted by a Superuser, not a Sky employee. Find out moreDid you actualy follow these stops as you never replaied saying if you did or not:
21 Jul 2024 04:30 PM
I did not understand
6.Sign out of Neflix on the Q box, start it up, press left and go to the help section to sign out.
7.Reboot SkyQ box by turning off at the wall or plugging out for 1 minute.
8.Go to your SkyQ box and launch the Netflix app on your SkyQ box.
point 6 - how can I sign out of Neflix on the Q box. What do you mean by saying " press left and go to the help section to sign out"?
I have tried 7 and 8 alone and this gives a temporary fix.
21 Jul 2024 04:52 PM - last edited: 21 Jul 2024 04:53 PM
It means to start up Netflix and press the left arrow which brings up the options, of course you can't do that if it won't start in the first place so don't worry about that bit.
Did you do 1 through 5 followed by 7 & 8? They are the important bits.
21 Jul 2024 05:25 PM
Forgive me - I am getting confused.
I see there are 9 points not 8. I have done points 8 & 9.only and that seems to give a temporary fix. I have not done 1-6 and I cannot do 7 because I cannot sign out of Netflix on my Q box. If I could do point 7 there would not be a problem.
21 Jul 2024 05:56 PM
@Anonymous
Forgive me - I should have replie to you.
21 Jul 2024 06:23 PM
Has anyone tried to access the live chat for Sky Accessibilty Customers
21 Jul 2024 06:25 PM
You have to be registered to contact the Accessibilty Team
21 Jul 2024 06:35 PM
I can't get onto Netflix from the main Sky Q box. It works on the mini box and on my iPhone. Any advice would be helpful
