19 Jul 2024 06:40 PM
Try the solution by Colin0000 it worked for me.
19 Jul 2024 06:57 PM
My Netflix won't move off red spinning stage I have reset box and turned off and on and still the same this has happened for the last 2 weeks
19 Jul 2024 07:01 PM
Posted by a Superuser, not a Sky employee. Find out moreI've moved your post into a large thread discussing this issue. See post 2 currently showing as the answer.
19 Jul 2024 07:24 PM - last edited: 19 Jul 2024 07:26 PM
Posted by a Superuser, not a Sky employee. Find out more@Laurss6 @PETROS+PETRA @Biggarscotland1 @Feathers
This is the fix that is working for others:
19 Jul 2024 09:04 PM
Netflix won't load. According to Netflix they have done an upgrade and sky need to put upgrade thru. Totally confused. I just get the swirling circle
19 Jul 2024 09:07 PM
Posted by a Superuser, not a Sky employee. Find out moreYour post has been moved to the large thread already discussing this.
19 Jul 2024 09:23 PM
Netflix it's loading it just keeps circling and doesn't load been like this for over 2 weeks
19 Jul 2024 09:33 PM - last edited: 22 Jul 2024 02:55 PM by Daniel-F
I've done this many times ... Sky then said I had signal problems that took 3 visits to get download speed which solved nothing ... Sky have no answer to the ongoing problems with Netflix customer problems ... (Removed)
Moderator note: Removed campaigning comment
19 Jul 2024 09:47 PM
when i try to access netflix, get the logo screen and a spinning circle. Most daysget this, occasionaly can access, therefore intermittent error. Can any clever soul diagnose?
19 Jul 2024 10:04 PM
@Pg666 @Thank you
19 Jul 2024 10:13 PM
Posted by a Superuser, not a Sky employee. Find out moreAs this is a Sky Q issue @Jemma+A I have moved your post to the Sky Q forum as this fix has been posted so do give this a try:
You can let Sky know about this via this form - https://forms.office.com/e/VGr0tUpv67
19 Jul 2024 10:30 PM
To fix it you need to do this:
20 Jul 2024 07:58 AM
Trying to sign into Netflix via web browser but doesn't recognize our email. Never had a Netflix account before it's part of the Sky package. Like for many it worked fine for ages now spinning red circle. Re booting occasionally works but inconsistent
20 Jul 2024 08:18 AM
@CornwallD wrote:Trying to sign into Netflix via web browser but doesn't recognize our email. Never had a Netflix account before it's part of the Sky package. Like for many it worked fine for ages now spinning red circle. Re booting occasionally works but inconsistent
Use the online Netflix password reset and try your Sky ID email, in fact try all emails you may have. Mine for instance is actually the sons as it was originally his Netflix account. If it is your Sky ID email and you've never signed in online then you need to do this in order to setup a Netflix online password.
