Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Message posted on 16 Jul 2024 06:29 PM
Re: Netflix not working for ages
My whole Sky isn't working either
Message posted on 16 Jul 2024 06:38 PM
Re: Netflix on sky q will not load
Why is this still an issue I get netflix through sky but can't watch it for spin circles
Message posted on 16 Jul 2024 07:03 PM
Netflix
Message posted on 16 Jul 2024 07:06 PM
Re: Netflix
Are you seeing a red spinning circle?
NOTE: I only provide help on the forum boards and NOT via Direct Messaging. DMs are switched off
Message posted on 16 Jul 2024 07:08 PM
Re: Netflix
I am
Message posted on 16 Jul 2024 07:11 PM
Re: Netflix
I've moved your posts into a thread discussing this.
Message posted on 16 Jul 2024 07:18 PM
@Olivia93 wrote:
Yes it is and we've refreshed the apps now still no luck
And what @Olivia93 is happening as you haven't said ?
Message posted on 16 Jul 2024 07:20 PM
Re: Netflix not moving from spinning red circle
Spinning red circle trying to get into Netflix on main tv.
Message posted on 16 Jul 2024 07:21 PM
I said it on my first post my netflix isn't loading or working
Message posted on 16 Jul 2024 07:23 PM
Re: Netflix: Red Spinning Circle on Launch
Hi had netfix problem trying to load
tried everything mention in the posts
canceled it in the end
then read a post about going on to nextflix on a computer log in and log out of any account showing open
unplugged q box switched back on problem resolved
Message posted on 16 Jul 2024 07:27 PM
Are you seeing a red spinning circle on launch ?
Message posted on 16 Jul 2024 07:33 PM
Yes it just stays on that everytime
Message posted on 16 Jul 2024 07:35 PM
Give this a try as it appears to working for others with the same issue:
Message posted on 16 Jul 2024 07:36 PM
Netflix’s is taking a long time to work
We are having trouble getting Netflix to work the wheel just keeps on turning, we are having to come out a few times and go into other apps before it finally works?
Message posted on 16 Jul 2024 07:37 PM
Re: Netflix’s is taking a long time to work
Give this a try:
