2507
This discussion topic is read only This discussion topic has been answered Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Locked
This message was authored by: Kirsty2704
When i put netflix on my tv it isnt loading. Im just getting a red circle
When I put Netflix on  through Sky it's not loading. I am jist getting a red circle. Its working fine on my sons TV upstairs and both our mobile phones
HELP
This message was authored by: Pg666
Re: Netflix: Red Spinning Circle on Launch
That's great - glad it worked. I find I have to do this every few months so at least next time you'll know to give it a try. Enjoy 😊
This message was authored by: MARIA20241
I've taken a screen shot of your fix!  Thanks again!
Re: When i put netflix on my tv it isnt loading. Im just getting a red circle
@Kirsty2704
I've moved your post into a long thread discussing this very subject.
This message was authored by: Debscree
Netflix not loading
Hi I can't get betflix to load on sky q. No problems on mobile device. I've tried re booting the system and refreshing the apps through the secret menu but still no luck. Can anyone help.
Re: Netflix not loading
@Debscree I have moved your post into the large thread all about the same problem that you are having there are a few work arounds to try until Sky and Netflix get this sorted out
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: MartinWilkinson
Cannot connect to Netflix, it just buffers
Cannot connect to netflix, just get the buffering logo at the bottom
This message was authored by: AndrewJohns
Re: Cannot connect to Netflix, it just buffers
We have exactly the same issue!  Not the first time it has happened recently but Neflix works ok on our other devices.
This message was authored by: Joanne691
Router
My Netflix keeps buffering I have reset the router and sky box but still the same
Re: Router
@Joanne691 I have moved your post into the large thread all about the same problem that you are having there are a few work arounds to try until Sky and Netflix get this sorted out
Hi. I recommend you try signing in to Netflix thru a laptop or mobile Ie not Sky then:
Sign Out of device through a Web Browser:
  1. Log into Netflix via the web browser.
  2. Highlight your profile picture (Top right corner).
  3. Click on Account.
  4. Under the Security and Privacy option, click on 'Manage access and devices'.
  5. Select the device name: (it may be called SkyQ ......or Sky UK Set-top box).
  6. Select--> click on the "Sign out" option on the SkyQ ......or Sky UK Set-top box.
  7. Sign out of Neflix on the Q box, start it up, press left and go to the help section to sign out.
  8. Reboot SkyQ box by turning off at the wall or plugging out for 1 minute.
  9. Go to your SkyQ box and launch the Netflix app on your SkyQ box.
This message was authored by: Richt86
Netflix not loading
Anyone else having this same issue with Netflix loading on sky? We had it earlier in the year and the fixes seemed to work. Nothing is working now. Done the 001, unplugged it, software update, router reset. Nothing fixes it.
The Netflix app on sky is clearly not fit for purpose, going to have to use the TV app instead. Come on Sky, how long have you been ignoring this issue for?
This message was authored by: SteveBrick99
Hi.  I logged onto Netflix using a web browser on my Mac, went to Account then ' Manage access and Devices' and signed out of Netflix on my Sky Q box only. Then restarted my Sky Q box by unplugging from wall socket for 30 seconds and Viola - Netflix started straight away !
This message was authored by: ann.c
I don't understand why I should have to go through all of this to access a priduct I am paying for. Utterly ridiculous. If Sky cannot deliver this service they should not be selling it
Have you tried the below? I know you shouldn't have to but it works for me and has worked for some others
try signing in to Netflix thru a laptop or mobile Ie not Sky then try the following
Locked
Answered - Go to Answer
