2507
This discussion topic is read only This discussion topic has been answered Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Locked
This message was authored by: VW1947
Re: Netflix: Red Spinning Circle on Launch
I have the same problem.  Even though it is a known problem, Sky sent out 2 engineers.  They were the ones who told me it was a known problem.  Will have to wait for a software update.  No idea how long that will take.
This message was authored by: josejdennis
Yeah they told me to update to latest software, I'm on 26 and latest is 27. However every time I do the update and it reboots etc, it still shows as 26.
You can't force it, just be patient and it'll update overnight at some point. That said there's a few people who seem to have lost all of the apps and I'm still wondering if it's due to their boxes updating.
This message was authored by: AndyScaife
Re: Can’t get Netflix on main Sky box but ok on all 3 Sky Q
Yes I have the red circle!
@AndyScaife
I've merged your post into a thread discussing this issue that some customers are experiencing. See the post currently marked as the answer (post 2).
This message was authored by: Maisye95
Re: Not connecting to Netflix
The Netflix App just has a spinning circle when entering, I have tried the 0,0,1 refres of Apps and doesn't seem to have made a difference. Other apps work fine in sky box and Netflix works fine on my phone etc so any ideas appreciated!
@Maisye95 have read of post 2 on page 1 of this thread
This message was authored by: Bobness
The answer (for me at least) which is still working for me on two boxes (main and mini) is to be found in my post 1501 and again below.
I had one person say there were going to try it but they have not given feedback. I've not even had a single thumbs up.
001 apps refresh alone will not fix this issue!
For my method which is derived from Sky phone help, resets the settings. You will therefore have to pair the remote again, setup apps usernames and passwords again and possibly set up channel favourites which I don't use. So make a note of all those items, you'll need them.
1. Perform Settings 001 <select> Reset Settings (first option) (to fix the issue)
  Couple of minutes to complete.
2. Perform Settings 001 <select> Apps > Refresh Apps. (to get the apps back)
   Wait 11 minutes or so for this to complete.
3. Put box into standby and disconnect from mains. Leave it off for 10 seconds.
    Power up the box again.
4. Pair up the remote.
5. Reconfigure username/ passwords in Apps
6. I'm told you may need to add channel favorites again (I don't use them.)
That's it. Did this a few days ago on both my boxes after weeks of problems. Been Okay since.
Bob.
This message was authored by: Orange-65
Problems watching netflix on sky q box
Netflix will not load up on my Sky Q box.
I've tried restarting etc many tims, no joy.
Howcan I get help from Sky when the only menas available to me is their stupid chat bot which runs out of choices!
Re: Problems watching netflix on sky q box
@Orange-65
Are you seeing a red spinning circle?
Yes, red circle and it goes no further...
@Orange-65
I've merged your post into the large thread discussing this issue that some customers are experiencing.
This message was authored by: Rowe008
Netflix freezing
I'm having issues with Netflix loading through my main Sky Q box.
If I reboot the box & try Netflix again it loads. However I'm having to do this daily & it's becoming annoying & frustrating.
What's causing it? Does the box need swapping out?
Re: Netflix freezing
@Rowe008
Locked
Answered - Go to Answer
