Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Message posted on 27 Apr 2024 09:52 AM
Re: Netflix: Red Spinning Circle on Launch
April 2024 and I am still getting this constant red circle, Netflix via smart tv straight in so clearly issue via sky box. Work arounds only work temporarily. How do I cancel Netflix through sky and go back directly to Netflix? Ridiculous this issue is ongoing. This thread was starts in sept 2023 as far as I can see!
Message posted on 27 Apr 2024 10:00 AM
@Corinne4 wrote:April 2024 and I am still getting this constant red circle, Netflix via smart tv straight in so clearly issue via sky box. Work arounds only work temporarily. How do I cancel Netflix through sky and go back directly to Netflix? Ridiculous this issue is ongoing. This thread was starts in sept 2023 as far as I can see!
Call Sky and cancel it and then resubscribe through the Netflix website.
Chances are you'll be paying more but it's your money. At least you can cancel it easier via Netflix.
Message posted on 27 Apr 2024 10:57 AM
I don't want to tempt fate, but mine has now been working perfectly for about a week. Maybe the fix has finally been downloaded to my Sky Q box🤞
Message posted on 27 Apr 2024 11:04 AM
You know you can use your sky subscribed netflix on any device you like?
Message posted on 27 Apr 2024 11:06 AM
I used the fix, shown on here months ago and touch wood.... everything's been fine since.
Message posted on 27 Apr 2024 11:38 AM
They do say that Netflix via the TV works flawlessly, why they're getting all worked up about the app on the box then I have no clue. It's £4.99, £10.99 or £17.99 for the three tiers standalone so they'll be paying less through their Sky account.
Message posted on 27 Apr 2024 12:06 PM
So I pay separately mostly because I'm too lazy to change it. Can't see why anyone who already has the discounted Sky price would change back.
Message posted on 27 Apr 2024 12:08 PM
Re: Netflix not loading
@Anonymous wrote:
@Donaldo70 wrote:I have the same issue. The answer is to dump Sky. Problem is where I live. Virgin Money needs to get here because Sky says they cannot help.
The answer(s) is in the 2nd post marked as the answer as it happens at:-
https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/td-p/4428388
The other option which would be by far favourite to my mind is to use the App on your Smart TV (presuming it has one) instead. I use it where possible over the Q Apps as the Q box is showing it's age now. Amazon Prime for instance on the box buffers badly for UHD whereas the TV is perfect and seems to have a better picture and audio both. They load quicker than the Q box as well and having specific buttons for Prime, Disney+ and Netflix is just the silver lining.
So what happens if the Firetvstick is also getting the red circle on the Netflix app but the Sky Q Netflix app is working as it should obviously I'd watch it via Sky Q if that was the case.
My FireTv stick connects to 5ghz and two DNS servers are listed in the Netflix app on my FireTvstick
192.168.1.1 (not using Sky BB at the moment)
8.8.8.8
Message posted on 27 Apr 2024 12:31 PM
8.8.8.8
Awesome, I'm happy for you. No idea what that's got to with it mind as no one mentioned a Firestick.
Message posted on 27 Apr 2024 01:43 PM
So a fix that's worked for me is to manually update the q box software.
Settings >system info>software version >setup>software download. Took about 10 minutes but Netflix has booted straight up since. Might be worth a try for some people.
Message posted on 27 Apr 2024 01:47 PM
I tried that (amongst other things) early onn. It did work, but not for long. Sky told me that they were rolling out an update for the Netflix app, so I'm guessing that's why mine now seems to be working. Hopefully everyone else will get the update soon
Message posted on 27 Apr 2024 01:50 PM
I'd tried everything else except that. Hopefully it's cured, time will tell. Suggests to me that box updates aren't automatic though, but i could be wrong.
Message posted on 27 Apr 2024 02:06 PM
According to Sky they are (or at least this one is), but they are not all updated at the same time. Fingers crossed that you get it soon 🤞
Message posted on 27 Apr 2024 05:18 PM
What are people's sky Q version and Netflix version. My main Sky Q box is being a pain with Netflix occasionally rebooting it fixes it but if I have any network issues it brings it back again and I just get the red circle. What makes it worse is I'm currently having electrical work done so networks up and down like a yo yo. Netflix on a mini and on other devices are fine it's only on the Q 2TB box that's having issues.
Message posted on 27 Apr 2024 05:19 PM
My netflix version is
Q260.000.05L-5.04-2.1.1 btw
