07 Dec 2023 07:23 PM
@Chodley - I have been following this thread daily for a few months now i thought i had carefuly wrote my post - please trust me when i say i have tried everything multiple times - thanks.
I have nothing in my Netflix managed devices - i even did a log out of all devices as soon as the new suggestion came in, refreshed, checked and checked again and again over the course of a week, the only thing showing is my other devices that i have since logged back in on after doing a full log out of everything
07 Dec 2023 07:24 PM
@Eddy99 wrote:@Chodley - I have been following this thread daily for a few months now i thought i had carefuly wrote my post - please trust me when i say i have tried everything multiple times - thanks.
Yeah I re-read your post and saw that and edited it in. Apologies.
Has to be multiple different issues with the same symptoms.
07 Dec 2023 09:43 PM
Thanks , it worked.
08 Dec 2023 08:41 PM
Is this sorted yet?
I was messing around and I found a fix. Log onto Netflix on a Web browser, go to your account and log out of Sky Q box!
This didn't actually log ne out of the sky box but after a few crashes it now opens immediately!
08 Dec 2023 09:40 PM
@Adam7666 wrote:Is this sorted yet?
Yeah a few people have found this works over the last week but unfortunately not everyone.
08 Dec 2023 10:09 PM
Hi,
I have now started to see this issue - when accessing Netflix as an Application through SKY.
Access through the Smart TV works fine.
Refreshing all Apps through the Installer menu made no difference.
09 Dec 2023 11:22 AM
I've. Given up! I'm moving in a couple of weeks I'll get them to sort it then hopefully! If not I'll cancel
10 Dec 2023 07:31 PM
Tried all the reboots and Sam88's solution, which initially worked fIr the past two weeks or so, now it's gone again.
This must be a software issue with the Skybox and Netflix. It is very frustrating.
And is not what any of us are paying for.
10 Dec 2023 07:35 PM
@JosephcN wrote:Tried all the reboots and Sam88's solution, which initially worked fIr the past two weeks or so, now it's gone again.
Yeah I don't think anyone is doubting it's a problem with the app on the Q box.
Tried the "sign out" solution again?
10 Dec 2023 07:40 PM
Has anyone tried checking the physical TV internet connection? Is the TV connected to the internet? I'm not talking about the skybox.
I was having this issue for months on and off, rebooting, resetting apps etc and then realised my TV was not connected to wifi.
when I connected my TV to wifi problem was solved
10 Dec 2023 07:53 PM
@Mike11970 wrote:Has anyone tried checking the physical TV internet connection? Is the TV connected to the internet? I'm not talking about the skybox.
Hmm. Don't see how that could be relevant to be honest but I've been surprised by seemingly unrelated tech issues before and good to hear yours is working.
10 Dec 2023 07:57 PM
I thought so as well.
but then I do have the Netflix app also on my physical tv that I now don't use and thought that as the tv didn't have wifi connected, maybe sometimes the sky Netflix app was sometimes using the tv app settings
not sure but I can honestly say I have not had an issue with Netflix in months after connecting the tv to wifi
10 Dec 2023 11:05 PM
Hi Really like to know when this netlix issue will be fixed its at a point where it is really annoying. now. Nobody should have to keep having to reset and take cables out and reboot so many times.
10 Dec 2023 11:34 PM
@missy1994 wrote:Hi Really like to know when this netlix issue will be fixed its at a point where it is really annoying. now. Nobody should have to keep having to reset and take cables out and reboot so many times.
Have you tried logging out and then back into your Netflix account. Do this though the Netrlix website.
10 Dec 2023 11:38 PM - last edited: 10 Dec 2023 11:45 PM
As BaileyGB says, have you tried the suggestion that's now marked as an Answer on this thread?
https://helpforum.sky.com/t5/user/viewprofilepage/user-id/2952035
