2507
This discussion topic is read only This discussion topic has been answered Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Locked
Avatar for Collinsc
Level 5 icon
This message was authored by: Collinsc
Re: Netflix often not working on SkyQ
Thanks all for the advive - will give them a go next time and contact sky if not fixed
This message was authored by: Eddy99
Re: Netflix app crashing/won't load
@Kirsty+S27
Nope changed setting - still red circle of doom and have never got Netflix to work on both mini boxes - ever
*Computer, Technology, and IT Literate*
This message was authored by: blobsie
It looks like the message claiming to be the answer by a sky representative should updated to remove the "answer" status
@blobsieUnfortunately she has a record of doing this when there is no answer, i have seen this before by the same person - jumps on one persons suggestion with no evidence it works for anyone.
This message was authored by: Mark187187
@Eddy99 she literally said she was marking it as an "answer" for visibility only.
@Eddy99 maybe if you had read the post correctly you would see that as @Mark187187 has stated that @Kirsty+S27 merely marked her post as the answer so it was easier to find and also asked for anyone having this problem to comment as to whether trying the fix in her post  fixed the problem or not as it would help the team that is investigating this
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@Laing1  - Thanks for the support Mr Superuser, we are not all as smart as you.
Support? All you had to do was read her post, not rocket science is it?
This message was authored by: Dee7
Thank you tk everyone for the replies and feedback!
@Anonymous- I have reported your post for being a rude [content removed]
Moderator note: language removed
This message was authored by: MarkJ22
Come on peeps let's all be nice and focus on the issue and the fix.
It's frustrating that Sky have no solution
This message was authored by: carrie171
Does anyone have a direct phone number for Sky?
I really can't tolerate this any longer and will be removing Netflix from my package and demanding a refund for the 'service' that I've paid for but have been unable to access for the last 6 weeks!! 😡
@Kirsty+S27 No, this doesn't work, in fact, my Netflix had started to work via On Demand, but since doing as you instructed via the app, it's stopped loading again!
Yeah everyone does. Look in Help on My Sky
You know you can use Netflix on another device?
@Chodley I am aware of that, but as I only have my phone, I'm not prepared to watch endlessly on that, when I pay to use Netflix on my TV!
Locked
Answered - Go to Answer
