1935
Discussion topic: Netflix: Red Spinning Circle on Launch
This message was authored by Colin0000 This message was authored by: Colin0000
Re: Netflix: Red Spinning Circle on Launch
Are all of these most recent posts the same person trolling or do people just not read anything previously posted?
Sky Q 2GB 32B106 - HDMI to TV, hard wired to router with WiFi disabled on the Q box
VM 256Mbps via rubbish VM HUB 3 router
Samsung S95C 55"
This message was authored by Joanne0617 This message was authored by: Joanne0617
Re: Netflix: Red Spinning Circle on Launch .
I have refreshed the apps but Netflix is still not working. Its been 4 days now and no netflix. Please help. Any advice will be appreciated.
This message was authored by Daniel0210 This message was authored by: Daniel0210
@Joanne0617
Please see post number 2 currently showing as the answer. We don't know when this update will be rolled out.
▪️I AM NOT A SKY EMPLOYEE ▪️
This message was authored by Stamen This message was authored by: Stamen
Re: Netflix issue
Plz help my Netflix won't connect on sky q, keeps circling red, don't updates, refresh apps, disconnected boxes , and router and still the problem continues, really frustrating
This message was authored by Shakes This message was authored by: Shakes
Netflix is not working on Sky Q
Netflix is not working on Sky Q. have done and tried everything and even contacted netflix but no response. All other apps through Sky Q are working find. Have tried going directly to Netflic APP and each time the logo appears and a red spinning pinwheel below and that's it. Tried requesting Netflix via voice control and same issue. Tried going to home page and selecting Netflic Top Pick Bridgeton and same issue. Switching off at the mains, cleaning sky card and shutting off at the router - still Netflix is doing the same thing. This is Day six of this issue. On day four Sky did have a prompt on clicking the top pick netflix programme saying that there was an issue with Netflix and they are trying to fix it.
Please help @Sky @SkyQ @skytv @Netflix
Re: Netflix is not working on Sky Q
@Shakes
I have moved your post into a thread already discussing this issue that some customers are having. See post 2 currently marked as the temporary answer.
This message was authored by Laing1 This message was authored by: Laing1
Re: Netflix issue
@Stamen I have moved your post into the larger thread all about the problem you are having please see post 2 which is currently marked as the answer
This message was authored by Ama56 This message was authored by: Ama56
Trying to log on to Netflix but just getting the circle going round and round
When logging in to Netflix I'm getting the red circle going round &  round not logging me in
Re: Trying to log on to Netflix but just getting the circle going round and round
@Ama56 I have moved your post to the larger thread all about the same problem you are having post markede as the current answer lets you know the current situation with this problem
This message was authored by Marc2009 This message was authored by: Marc2009
Re: Netflix won’t load
As ame here been doing it for 2 days now
This message was authored by Seashore This message was authored by: Seashore
Re: Netflix sporadically not loading
Having exactly sane issue as you and we pay Sky for netflix so don't expect that to fix things.  We've tried all the fixes suggested without success so assume uts yet another sky fault. Not impressed.
This message was authored by jubug This message was authored by: jubug
It's been three days now??
@Marc2009 this is a know problem see the link below and the answer in post 2
https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/td-p/4428388
This message was authored by Jayewing This message was authored by: Jayewing
I do the refreshing if Apps, the switch off at plug etc. Then you have to wait 24hrs for the refresh. Sometimes it works but it will go back to the same issue a few days later. Best solution seems to be to leave Sky, no other supplier seems to have this issue. Phoned Sky about it and the woman asked me what worked the last time!!! I hung up, absolute rubbish. We pay Sky a lot of money, they should sort this out.
This message was authored by lifeat39 This message was authored by: lifeat39
Hi all, I've reset my SkyQ Box and since this, no issues with Netflix loading Note: Not factory reset. Good luck
