1775
Discussion topic: Netflix: Red Spinning Circle on Launch
This message was authored by Collinsc This message was authored by: Collinsc
Hi
Netflix is often not working on SkyQ. We have checked the Netlfix website and there are no problems with Netflix itself.
We rang up before and sky had directed us to the hidden menu to "refresh apps". However, the "Refresh apps" is no longer there, or perhaps moved?
We have Sky Broadband Ultrafast 1 (FTTP) and are getting good speeds.
Advice appreciated on what might be causing this issue, and where we can locate "Refresh apps".
Moderator note: subject of thread updated to better reflect the conversation
This message was authored by Chloe-W22 This message was authored by: Chloe-W22 Answer
Re: Netflix: Red Spinning Circle on Launch
Posted by a Sky employee
Hi everyone,
I wanted to continue my thanks for your contribution to this thread, and continuous understanding while we investigate the Red Ring issue.
Our teams have been working closely with Netflix where we have discovered a bug upon launch of the app that requires the background memory to be cleared. We know through the examples you have shared with us through our secure form workarounds such as:
Reset the settings
Sign Out of device through Web Browse
Opt out of A/B test groups
will resolve the red ring for a limited time, we ask you continue to complete these actions whilst we reach a complete resolution.
We're still interested in tracking how many of our customers are having this problem so we have kept our secure form open, if you wish to register your examples please find our form here - https://forms.office.com/e/VGr0tUpv67
Thank you again,
Chloe-W22
Community Manager
Have a story you want to share with us? Send your Thanks to Sky here
This message was authored by Teresa+SB This message was authored by: Teresa+SB
Netflix Won't Load / Spinning Circle
Netflix will not load - keep buffering
Moderator comments: edited title
Re: Netflix on sky q will not load
Assume you have tried rebooting your Q box @Teresa+SB
This message was authored by Bernieboy14 This message was authored by: Bernieboy14
I can’t load the Netflix app
I have the circle going round when I try to access the Netflix app on the sky menu
Tried that
@Teresa+SB wrote:
Tried that
Hi @Teresa+SB
Have you tried refreshing the Apps in the Hidden menu.
Select Apps 
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
This message was authored by Dicks+taxi This message was authored by: Dicks+taxi
We had sky fibre fitted on Monday we cannot connect to apps on tv or the hive and Alexa
This message was authored by Robin34 This message was authored by: Robin34
Netflix sporadically not loading
Netflix app not working on Sky Q box. One day it loads, the next day it doesn't. Now it seems to be completely defunct. I've tried Sky box on/off, updating Sky box, 0,0,1 on settings and apps refresh, everything that has been prescribed as a fix. Now assuming that there is either an inherent issue with Netflix app on Sky Q experienced by many, or my Sky Q box is malfunctioning. Has anyone else managed a permanent fix? If I paid for Netflix subscription through Sky would this magically fix the issue? Just being sceptical 😛 thanks in advance.
This message was authored by Quoman7 This message was authored by: Quoman7
Re: Netflix sporadically not loading
Hi @Robin34 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
Thanks @Quoman7. The Netflix app has been working on SkyQ the past few weeks, but again decided to stop loading yesterday and today. So I took your advice and turned off router and sky box and reloaded it all. Worked a treat! If it requires this level of rebooting every couple of weeks I can live with it. But if it starts playing up frequently like it did before, sad times. For now, your advice has worked so thank you. Kind regards.
This message was authored by Lexi+Neave This message was authored by: Lexi+Neave
I've tried this and Netflix still won't load. I've turned everything off and unplugged to but nothing helps
This message was authored by Ilya+Joaquin+Marc This message was authored by: Ilya+Joaquin+Marc
I've had the same problem for a few weeks.
This message was authored by Sarah2714 This message was authored by: Sarah2714
I am constantly getting the loading page for Netflix and it just doesn't load! Have tried unplugging, have tried the hidden apps refresh, nothing is working, it's getting ridiculous now.
This message was authored by Colin0000 This message was authored by: Colin0000
Welcome to my (and others) world 😞
A reboot is the only thing that will resolve it although not permanently, the last time I bothered it took all of 12 hours maximum before it fell over again.
I didn't know the Apps refresh can take 24 hours so I'm not sure of what use that is, it's made no difference to mine anyway.
https://helpforum.sky.com/t5/Sky-Q/Netflix-app-not-working-on-Sky-Q-001-settings-does-not-work/m-p/4...
Sky Q 2GB 32B106 - HDMI to TV, hard wired to router with WiFi disabled on the Q box
VM 256Mbps via rubbish VM HUB 3 router
Samsung S95C 55"
This message was authored by WestLondon1991 This message was authored by: WestLondon1991
Same issue for me - Netflix just spins and spins and never loads, clearly an issue with Sky. Is this being investigated?
