Discussion topic: Need a sky box for bedroom
This message was authored by: Robynlittle
I pay for sky whole room but don't have a sky box for my bedroom only downstairs how do I get one? Or can I watch sky without a box?
Re: Need a sky box for bedroom
@Robynlittle You contact Sky and ask them to send you one.
Hi @Robynlittle
Do you have Sky Q or Sky Glass or  Sky Stream?
With Sky Q it's a Multiscreen subscription required for Additional mini boxes.
If you have Stream or Glass it's a Whole Home subscription.
You can have up to four minis installed on loan with Sky Q,   each subject to a one off upfront charge and all under by one single Q monthly Multiscreen subscription
However only two minis can be used simultaneously on all 2 TB boxes and the 1 TB UHD Main boxes to watch Sky Q content.
The original 1 TB non UHD box (32Cxxx) only permits the use of one mini at a time.
If Sky Apps are already being used on some of the minis these will not normally be counted as in Q use and therefore can be used in addition to the above limits.
See the following link for the Versions of main Q box referred to above.
https://www.sky.com/help/articles/sky-software-updates.
It should also be remembered that minis cannot set or view UHD recordings or content.
Assuming you mean "Whole home" that's a Glass/Stream thing, not Q
