8
This discussion topic has been answered Discussion topic: Name of satalite
This message was authored by: Sylv2
Name of satalite
Just got new tv and to tune in it's asking for the satalite name. Where would I find this?  Looked on setup all it says is 'locked' can anyone help?
Re: Name of satalite
@Sylv2 wrote:
That's what happened before with other tv , unfortunately this one needs me to identify the satalite to tune in. Never seen this before!  Thanks anyway.
Hi @Sylv2
Identifying the Satellite would be necessary if you were trying to Tune a Television that has an inbuilt Satellite tuner.
However to do this you would need the Television connected directly to the Satellite dish.
Unfortunately the Satellite tuner in the television will not function with Q Dish LNB
Do you have a Sky tv box? If so, Sky+? Or Sky Q? Or Sky Stream?
Avatar for Sylv2
Sky q and trying to tune in mini box to new tv
There's no tuning in required. Just connect the HDMI cable between your Sky Q box and your TV, and then select the HDMI port you've plugged it into.
Avatar for Sylv2
Hi @Sylv2
Hi @Sylv2
That is a message from the TVs internal satellite tuner and not SKY
Just use your TVs own remote to skip and select the HDMI port that your SKY box is connected
Avatar for Sylv2
Thanks that's probably why it's asking for the name of satalite.
Avatar for Sylv2
Will give that a try and if no success take tv back. Thanks for help.
