This discussion topic has been answered Discussion topic: Name of satalite
Message posted on 23 Jul 2024 09:53 PM
Just got new tv and to tune in it's asking for the satalite name. Where would I find this? Looked on setup all it says is 'locked' can anyone help?
Message posted on 23 Jul 2024 10:14 PM
@Sylv2 wrote:
That's what happened before with other tv , unfortunately this one needs me to identify the satalite to tune in. Never seen this before! Thanks anyway.
Hi @Sylv2
Identifying the Satellite would be necessary if you were trying to Tune a Television that has an inbuilt Satellite tuner.
However to do this you would need the Television connected directly to the Satellite dish.
Unfortunately the Satellite tuner in the television will not function with Q Dish LNB
Message posted on 23 Jul 2024 09:58 PM
Re: Name of satalite
Do you have a Sky tv box? If so, Sky+? Or Sky Q? Or Sky Stream?
Message posted on 23 Jul 2024 09:59 PM
Sky q and trying to tune in mini box to new tv
Message posted on 23 Jul 2024 10:00 PM
There's no tuning in required. Just connect the HDMI cable between your Sky Q box and your TV, and then select the HDMI port you've plugged it into.
Message posted on 23 Jul 2024 10:07 PM
Hi @Sylv2
Message posted on 23 Jul 2024 10:15 PM
Hi @Sylv2
That is a message from the TVs internal satellite tuner and not SKY
Just use your TVs own remote to skip and select the HDMI port that your SKY box is connected
Message posted on 23 Jul 2024 10:23 PM
Thanks that's probably why it's asking for the name of satalite.
Message posted on 23 Jul 2024 10:24 PM
Will give that a try and if no success take tv back. Thanks for help.
