Discussion topic: NOT RECORDING ANYTHING ON SERIES LINK AND IMPOSSIBLE TO SPEAK TO ANYONE TO SORT IT OUT
Message posted on 15 Aug 2025 03:25 PM
The series link is not working on anything and it impossible to speak to Technical support which is annoying as we are paying a lot of money for a substandard service with no human back up. The system isn't easy to use and I do not feel I have had any constructive advice as to how to resolve this. I am considering cancelling my subscription.
Message posted on 15 Aug 2025 03:42 PM
Re: NOT RECORDING ANYTHING ON SERIES LINK AND IMPOSSIBLE TO SPEAK TO ANYONE TO SORT IT OUT
For which you'll need to eventually speak to Sky.
We don't know what you've tried already so…
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Message posted on 15 Aug 2025 04:10 PM
@RCK77 wrote:I am considering cancelling my subscription.
