Discussion topic: Mysky_1802 already subscribed . Tried reboot but no difference
Message posted on 11 Oct 2024 03:08 PM
I tried to watch sky cinema which I subscribe to, a message tells me to upgrade using the red button. Then message already subscribed and code MYSKY_1802 appears.
Message posted on 12 Oct 2024 12:09 AM
Re: Mysky_1802 already subscribed . Tried reboot but no difference
@Frank61 wrote:I tried to watch sky cinema which I subscribe to, a message tells me to upgrade using the red button. Then message already subscribed and code MYSKY_1802 appears.
Have you tried pulling the plug for a few minutes ? This clears some system glitches. Also it may be worthwhile rebooting your router.
if you have only recently added sky cinema it can take a few hours for the subscription to activate
Message posted on 12 Oct 2024 09:07 AM
Re: error code MYSKY_1802 on sky glass
No This isn't helping. I have skyQ and even when I start cinema on main home page there is a upgrade to cinema option
Message posted on 12 Oct 2024 09:34 AM
@Frank61 wrote:No This isn't helping. I have skyQ and even when I start cinema on main home page there is a upgrade to cinema option
You have posted in the sky glass / stream forum . You will need to start a new thread in the sky Q sub forum
Message posted on 12 Oct 2024 10:01 AM
I've moved the above posts over to this new Sky Q thread.
Message posted on 13 Oct 2024 09:51 AM
If you go to the sky cinema on the sky go app can you view films or do you get the message to upgrade on the movie channels. If you can view the films the signal may need to get sent to your viewing card again.
My Set up
Sky Q 2tb 32B0
Samsung QE55QN85A
Sky Q Mini x 3 via wifi using Grain Connect FTP
Samsung S23 Ultra
Samsung HW-Q800A/XU 3.1.2 Wireless Sound Bar
HP Pavilion 14-dv1629sa 8gb ram Laptop Windows 11 Home
Joined Sky Community 8th November 2010
Click the following link if you want to Send your Thanks to Sky
Message posted on 13 Oct 2024 01:52 PM
Thank you. Yes I can watch on my mobile sky go app. I will contact sky to send signal to viewing card. Thanks again
Message posted on 13 Oct 2024 02:04 PM
I had the same issue with Sky sports till I got to someone that could send the signal to my card again
My Set up
Sky Q 2tb 32B0
Samsung QE55QN85A
Samsung S23 Ultra
