Discussion topic: Mybox keeps losing internet connection. I reset it it and it lasts a few minutes before cutting out
Message posted on 20 Aug 2023 12:26 PM
My sky q box keeps losing internet connection. I have tried reset but it only lasts a few minutes before cutting out again
Other things are connected with no problems.
Message posted on 20 Aug 2023 12:49 PM
							Re: Mybox keeps losing internet connection. I reset it it and it lasts a few minutes before cutting
Hi @Pacman1234
Are you carrying out a Network reset as follows;
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Message posted on 20 Aug 2023 12:58 PM
Hi old fella, yes, I have done that. My provider is talktalk and I get WiFi connected but within a few minutes the box loses the connection again. I have completed the process around 10 times now.
Message posted on 05 Nov 2023 06:03 PM
Mine is the same. Internet connecting for around 5 minutes then goes into disconnected. I'm on talk talk. No problem with any other linked Wi-Fi. Fire stick. Tablets etc all fine Was there a solution to this ?
Message posted on 11 Nov 2023 05:40 PM
I have exactly the same problem, was totally fine when we were with sky, but as soon as we moved suppliers (SKY couldn't offer full fibre in our area but others could) we've had problems the in laws have the same issue, they ended up getting a new Sky Q box and as far as I know they haven't had an issue since.. 🫠 think it's actually SKY trying to get us to swap back 😂
Message posted on 11 Nov 2023 07:47 PM
Thanks for replying. I explained it to sky who sent an engineer and installed a booster which has solved the problem.
Message posted on 11 Nov 2023 07:54 PM
@Pacman1234 Ahh good to know, I'll give them a shout tomorrow and see what can be done, it's rather annoying as you know 😅
Message posted on 05 Feb 2024 05:30 PM
I found some help addressing this. Turn off "Eco" and also switch off the 2.4GHz signal on the boxes. Takes a while (a day) to settle down but since doing this I haven't had any further problems. Big relief because it's been a right pain for months
Message posted on 20 Apr 2024 03:17 PM
Mine continues to do this. I've had engineer out twice. They fiddle with settings and it's fine for a few days then back to internet drop out. My daughter has autism and I'm getting stress from her so much so I'm thinking of cancelling my sky package altogether
Message posted on 20 Apr 2024 03:49 PM
I was a little cheeky, I used the "need some help?" Bit on the My Sky app and ordered a replacement box. (Fixing a problem, Sky Q equipment, choose Sky Q box is noisy or warm / no power and there's a blue "replace your Sky Q box" link. They'll arrange for a new box to be delivered in a couple of days, they'll swap the box over on delivery. Haven't had any issues (touch wood) since I got the replacement, can only guess it was a hardware fault.
Message posted on 21 Jul 2024 10:03 PM
I've had this same problem approx every 12 months.
Box gets hot. Is a bit noisier. Internet drops.
reset, reconnect, ok for a few minutes. Drops again.
turn the box off for a few hours solves the problem for a while but it soon returns. Hotter weather seems (not proven) to make it worse.
a replacement box fixes the issue.
now onto 3rd box in 3 years.
seems like they should be looking at the problem and looking for the cause, but hey, not my business model!!!
