Discussion topic: My wife spoke to sky about no Netflix , followed the sky advisor’s instructions and now we have no s
Message posted on 15 Aug 2024 10:29 PM
We followed a sky advisors instructions to get Netflix working again and now have no sky service at all!
Message posted on 16 Aug 2024 07:14 AM
Re: My wife spoke to sky about no Netflix , followed the sky advisor’s instructions and now we have
hi @SteveB151
Please can you give us any details you can regarding what actions have been taken.
What messages are you now seeing ?
Do you have your own dish or are you connected to a communal system ?
Please give as much info as you can.
Message posted on 16 Aug 2024 09:52 AM
We were told to reset the sky Q box and now it just says no satellite signal. We are connected to a communal dish. None of our neighbours has a problem and this only started when we called Sky to see why we could no longer get Netflix to work!
Message posted on 16 Aug 2024 10:06 AM
@SteveB151 wrote:We were told to reset the sky Q box and now it just says no satellite signal. We are connected to a communal dish. None of our neighbours has a problem and this only started when we called Sky to see why we could no longer get Netflix to work!
press Home
Scroll to Settings - but do not press enter/select at this point
Press 0 0 1 in sequence followed by the Enter/ select button
you should now get the engineer's menu
Select the LNB Type & set to SCR if necessary
After changing the LNB type power down (switch off at mains or unplug) your SKY Q box and restart it for the change to come into effect
Message posted on 17 Aug 2024 10:28 AM
Did all that. No good. Going to call sky back. At this rate I can see me cancelling my subscription!
Message posted on 17 Aug 2024 10:43 AM - last edited: 17 Aug 2024 10:47 AM
hi @SteveB151
Did you have to change the mode to SCR ?
If so, as mentioned, you must completely power down the box after chaging it to make sure it is changed
Edit : BTW after a box reset your remote will need re-pairing by pressing & holding 1 & 3 & need to make sure it has line of sight of the box until paired as it uses IR until it is paired
