Discussion topic: My volume on sky remote is not working even with replacement remote
This message was authored by: Jane210774
I have pressed 1 and 3 together several times probably about ten times and it said my tv does work with it. Yet it worked when they installed it ? The power button also does not work. Neither does the button to change to hdmi.
This message was authored by: ThePope27
Re: My volume on sky remote is not working even with replacement remote
Hi @Jane210774,
Try fully resetting the remote by holding 7+9 and then pressing and holding 1+3 to reconnect it via Bluetooth, it should then ask you if you want it to control your TV, just enter the brand and it should do the rest 🙂
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Avatar for Jane210774
Thank you but I have tried that several times and it just keeps saying my tv does not support it. But the engineer managed to do it when he installed it ??????
Hi @Jane210774
What brand and model is your TV?
Panosonic
@Jane210774
Try Vestel as the brand instead of panansonic when setting up the remote 🙂
Thank you I will try it.
