Discussion topic: My volume buttons have stopped working on my sky q remote. All others are fine
Message posted on 04 Jan 2024 08:26 PM
The volume buttons on my remote have completely stopped working. All others functions are fine just these. How do I get a new remote
Message posted on 04 Jan 2024 08:47 PM
Re: My volume buttons have stopped working on my sky q remote. All others are fine
Hi @Perkyp
Have you tried completly resetting your Bluetooth remote.
Message posted on 04 Jan 2024 09:08 PM
I tried this as I know it works via signal so made sure there was nothing in the way when doing this. Have tried this more than once. Like I say all other buttons work fine. It's just the volume
Message posted on 04 Jan 2024 09:10 PM
Hi @Perkyp
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment.
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
Message posted on 05 Jan 2024 12:37 AM
@Perkyp wrote:I tried this as I know it works via signal so made sure there was nothing in the way when doing this. Have tried this more than once. Like I say all other buttons work fine. It's just the volume
All other buttons use bluetooth. Only the volume uses IR (I think you meant that when you said "signal"?) to the TV and the reset you tried should have re-configured the remote with the IR codes for your TV so maybe its IR transmitter is faulty.
does holding down the power button turn the TV on and off? That uses IR too.
Message posted on 19 Aug 2024 12:12 PM
Mine did the same with my Samsung tv, you need to re program your remote to your tv in sky q settings.
Message posted on 09 Nov 2024 08:24 PM
The settings on the Q box fixed my problem, thank you to the person that advised this 🙂
Message posted on 11 Mar 2025 04:04 PM
Message posted on 11 Mar 2025 04:08 PM
@Debraheslop
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (I’m not sure if this is available to customers in the Republic of Ireland).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
In the meantime if you have an Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
Message posted on 24 Nov 2025 06:17 PM
Thank you. The reset worked a treat. It was so easy.
