04 Jan 2024 08:26 PM
The volume buttons on my remote have completely stopped working. All others functions are fine just these. How do I get a new remote
04 Jan 2024 08:47 PM
Hi @Perkyp
Have you tried completly resetting your Bluetooth remote.
04 Jan 2024 09:08 PM
I tried this as I know it works via signal so made sure there was nothing in the way when doing this. Have tried this more than once. Like I say all other buttons work fine. It's just the volume
04 Jan 2024 09:10 PM
Hi @Perkyp
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment.
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
05 Jan 2024 12:37 AM
@Perkyp wrote:I tried this as I know it works via signal so made sure there was nothing in the way when doing this. Have tried this more than once. Like I say all other buttons work fine. It's just the volume
All other buttons use bluetooth. Only the volume uses IR (I think you meant that when you said "signal"?) to the TV and the reset you tried should have re-configured the remote with the IR codes for your TV so maybe its IR transmitter is faulty.
does holding down the power button turn the TV on and off? That uses IR too.
19 Aug 2024 12:12 PM
Mine did the same with my Samsung tv, you need to re program your remote to your tv in sky q settings.
