180
This discussion topic is read only This discussion topic has been answered Discussion topic: My viewing card keep's dropping in and out and/or I see a message asking me to upgrade
Locked
This message was authored by: Darren+Ives
Re: Sky viewing card error message
Same issue here over last hour or so. Requires a switch off to get viewing back, and happens again a short while later.
This message was authored by: AnnoyedAndroid
Re: Viewing card
Totally agree, waste of time trying to contact sky, they are aware of it so let them sort it out.
This message was authored by: Johnk6
Viewing card not active
Keep getting message to check viewing card
Re: My viewing card keep's dropping in and out.Would like an online chat if possible ?
This message was authored by: y1t1f1c1
Viewing Card Can’t be read
Sky Q mini box keeps disconnecting Message says Viewing Card can't be read
This message was authored by: type-r
ETA - Sadly it's back again! False dawn.
This message was authored by: Welly01
Viewing card
Viewing card message keeps flashing up on screen then disappears Have done all the usual things eg restarts callback but still happening
This message was authored by: MISFIT1966
Same issue here, I got through to the contact centre, it is a problem they are trying to deal with,  it may take 48 to 72 hours! They said they had sent a signal out whilst I was on the call, it worked for a few minutes, but then same message again and blue screen.
Sky should refund people for the amount of hours/days this is causing an issue for, over to you Sky....
This message was authored by: MarshysMum
Re: Viewing card
I'm having exactly the same.
gone through removing card, tried wiping and replacing.
Tried restarting box, still happening
This message was authored by: matty147
Been having this viewing card issue too. Saw that Sky called but didn't answer but I guess it's to do with this issue.
This message was authored by: Leannefox
My new multiscreens asking for a viewing card
My new multiscreens are asking for a viewing card it's saying it's not reading the viewing card
This message was authored by: Sorbie
Keep losing signal
Movie channels are mixed up and says on screen,you cannot purchase this programme
This message was authored by: William+P
Error message on sky q -ensure correct viewing card is inserted
This problem is happening every 10 minutes
This message was authored by: Craig_S_74
Viewing card issue possibly reader
Please ensure correct viewing card is inserted with the chip facing up. Like its happening every 5 min on main box today.
This message was authored by: CanardNoir
Problem with this board....
Why am I getting this when I try to access a page about the viewing card issue?
Sorry, you don't have access to this page
An Unexpected Error has occurred.
  • Your request failed. Please contact your system administrator and provide the date and time you received the error and this Exception ID: 1BBA25DB.
    Click your browser's Back button to continue.
Locked
Answered - Go to Answer
