Discussion topic: My tv wont connection to Internet
This message was authored by: Natasha241
I'm trying to connect my tv to my Internet but it's saying unsuccessful connection try again or may have to use a sky q booster
Re: My tv wont connection to Internet
Hi @Natasha241
Avatar for Natasha241
Level 0 icon
Done all this and still nothing
Who is your broadband supplier @Natasha241 ?
Level 0 icon
Sky is my broadband supplier
Hi @Natasha241
If you attempted the procedure in my earlier post exactly what happened at each step?
Level 0 icon
Yes I have followed every step
Level 0 icon
I reset it and it went green so I pressed and holded the wps button but it searches but says unsuccessful connection
Hi @Natasha241
Did you carry out the Network reset on the main Q box?
