Discussion topic: My tv wont come out of stand by.tried remote & buttons on tv
This message was authored by: stuzy
My tv says on stand by. It wont come on manually either
Re: My tv wont come out of stand by.tried remote & buttons on tv
Try turning your TV off at the mains then turn it back on after a few minutes.
Hi @stuzy
Work through the following link and it will give a conclusion
https://www.sky.com/help/articles/sky-q-box-wont-turn-on-t2
If its your Sky box stuck on stanby, do as mentioned in the post above.
If it is your TV stuck in  standby mode, would suggest removing the power from the TV for a few minutes and trying to power on the TV again.
