Discussion topic: My tv won’t connect to the internet
Message posted on 29 Jul 2023 05:13 PM
I tried my tv today, just wanted to watch something on Netflix, my tv said it wasn't connected to the internt
It is everything is connected
phone, pc's kindle
My tv is a LG and it has a wired connection, everything is plugged in correctly, this had just occurred over the past 24 hours
is it worth calling Sky?
Message posted on 29 Jul 2023 05:17 PM
Re: My tv won’t connect to the internet
phone, pc's kindle
Hi @Derrick241
You need to be clear whether it is your LG TV not connecting to your internet or whether it is your Q Box!
No good calling Sky if it is your LG TV connected by Ethernet.
Message posted on 29 Jul 2023 05:21 PM
The Sky q box isn't connected, it won't connect to the internet, keeps telling me to check my connection, it's connected to the router and the Sky q box with an Ethernet cable, won't even connect through Wi-Fi
Message posted on 30 Jul 2023 08:32 PM
Well asking here was a waste of time, only one reply and that was pretty useless
After waiting 30 odd minutes for Sky to answer the phone
Goole was a lot more help
i was all down to a WPS button on the side of the router (very hard to find)
That had to be reset
Did that and my Sly Q is working now
Message posted on 30 Jul 2023 08:42 PM
phone, pc's kindle
To be fair to the poster who replied they did ask if it was your LG TV that you posted about as your post does suggest it was the TV at issue not Sky Q, not even a mention of SKy Q in your post, had you been more clear the replies would have been also.
Message posted on 31 Oct 2023 06:22 PM
In my case it is my TV that wont connect to the internet. It is LG. I have Sky Broadband which previously connected fine to the TV but for the past 6 months it would not connect?? I didnt realise I could connect to Sky brpadband via my Sky Q Box. Can I connect both my Sky Q box and the TV to internet. While I realise I can get Netflix throuugh Sky - there are other Apps on the TV whiich I cant use without a connection. Is this a TV issue or is the connection to Sky preventing my TV from connecting?
Message posted on 31 Oct 2023 06:28 PM
I am not an expert but what errors do you get when trying to connect your TV to your home wifi ?
Anything else you can advise ?
As an aside if your TV won't connect to your wifi you could try using an ethernet cable from your TV to the SKY Q box
