2
This discussion topic has been answered Discussion topic: My tv won't connect to my sky q box and there's a red fault light showing on the box which is on the
This message was authored by: Kerrimac78
Tv won't connect to sky q box
This message was authored by: MightyQuinn Answer
Re: My tv won't connect to my sky q box and there's a red fault light showing on the box which is on
Hi @Kerrimac78   You are going to have to provide more details. There isn't any fault light on a Sky Q box. The red light shows while it is recording or downloading and the power light turns red in power save mode. The first thing to try is power reboot your TV and Sky Q box.
Avatar for Kerrimac78
Level 0 icon
Sorted
Sorted
Answered - Go to Answer
