Discussion topic: My tv screen keeps freezing and going to small square s
This message was authored by fostermay1971 This message was authored by: fostermay1971
I have disconnected everything thing to do with my sky and reconnected as I'm getting small squares on my tv screen and sometimes freezes.
Re: My tv screen keeps freezing and going to small square s
Seen similar issues in the past @fostermay1971
If the issue continues then it's best to get an Engineer as it looks like the box may have issues
