Discussion topic: My tv is on,but no sound and the sky remote isnt responding to changing channels or sound
This message was authored by: CarV
My TV is on,but my sound isn't working and I can't turn the channels over
Re: My tv is on,but no sound and the sky remote isnt responding to changing channels or sound
Hi @CarV
Try rebooting your Q box.
When the Q box is back on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Avatar for CarV
Hi Thank-you for response, but I've tried this x2. I did a Google search.
I've rang Sky x2..waited for 20 mins then the call disconnects
Frustrated 😠
Can the remote do anything at all?
