Discussion topic: My tv is freezing on all channels and goes in slow motion
This message was authored by: sue+thompson
It freezes on all channels,  when it does go again it skips in slow motion
Re: My tv is freezing on all channels and goes in slow motion
Hi @sue+thompson
