Discussion topic: My television is not turning on
This message was authored by: shiran
I I have equipment protection insurance my Television is not working I try turning it on but no results, then I unplug it from the main  with no results I also change the battery in the remote it still didn't work
Re: My television is not turning on
Hi @shiran
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
