Discussion topic: My skybox isn’t working upstairs yet is downstairs.
Message posted on 05 Mar 2024 01:49 PM
It's telling me it can't connect to the telly...been trying all day to fix it n now I'm texting you as feeling stressed out now..
Message posted on 05 Mar 2024 05:00 PM
Re: My skybox isn’t working upstairs yet is downstairs.
@Luna2024 Afraid you are not contacting Sky's customer services on here, this is a customer to customer forum where customers help each other.
Have you tried rebooting your main Q box ie
Then
Reboot the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 05 Mar 2024 05:24 PM
Hi @Luna2024
Try a Network Reset on the mini.
