Discussion topic: My skyQ box won't connect to the internet.
Message posted on 30 Mar 2024 09:01 PM
My skyQ box won't connect to the internet, so can't access prime etc. I've tried all the advise i.e. reseting the network, pushing the WPS button on the router, and nothing seems to work, any advice will be greatly appreciated.
Message posted on 30 Mar 2024 09:06 PM
Re: My skyQ box won't connect to the internet.
Hi @Parker121
Message posted on 30 Mar 2024 09:11 PM
Hi ya,
Thanks very much for getting back to me so quickly.
I'll give it another try, but have tried all that and it just comes up with the error message, sorry the sky box failed to connect to the internet, you may need a sky Q booster??
Thanks again anyway,
Rob
Message posted on 01 Apr 2024 08:51 AM
I think it was a sky fault mine was the same last night connected to router but not internet but everything thing else was connected to internet
