Discussion topic: My sky tv wont connect to sky broadband router
Message posted on 23 Jul 2024 08:35 PM
I have tried multiple times pressing the wps button - it flashes smber but jpt tirnimg green
Message posted on 23 Jul 2024 08:40 PM
Re: My sky tv wont connect to sky broadband router
Hi @Nicola_
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done..
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
Message posted on 23 Jul 2024 09:17 PM
@oldfella thanks for replied. I've tried all the instructions (found your previous thread) and just been on the phone to them. Now sending an engineer out in five days - joke! Any other tips, let me know
Message posted on 23 Jul 2024 09:21 PM
@oldfella its come back on now. Not sure why. Thanks for replying.
Message posted on 29 Jan 2025 02:52 PM
M S ,,, Hello i just pressed the WPS button on the SIDE of my new router until another YELLOW light came on don t press the RESET button should have been a WPS button down the side of your router hub then it connecteD to my Sky Q on my T V 😄
