Discussion topic: My sky tv is working fine except I can’t access on demand or catch up as it is saying I have no intr
Message posted on 30 Mar 2024 08:58 PM
My sky tv is working fine except I can’t access on demand or catch up as it is saying I have no intErnet connection, how can my tv be working if this is the case?
Message posted on 30 Mar 2024 09:06 PM
Re: My sky tv is working fine except I can’t access on demand or catch up as it is saying I have no
Hi @Cathie22
Live TV comes via Satellite and not Internet.
Try resetting the Network.
