Discussion topic: My sky tv is not connecting to my broadband. I have spent 2 hours trying to get through to a HUMAN
This message was authored by Barrymitchell22 This message was authored by: Barrymitchell22
I have tried for 2 hours to get through to a human. This has not been working for days and I need to speak to someone urgently to fix this. Sky TV not connecting to my broadband. Have tried all the standard tricks or turning both off and back on. No joy. Even left them switched off for the night. Issue with the Sky TV box.
Re: My sky tv is not connecting to my broadband. I have spent 2 hours trying to get through to a HUM
Hi @Barrymitchell22
Assume you have tried a Network reset on your main Q box as follows?
Barrymitchell22
Hi. I've tried all of this a few times. Even after a full reset. Switched tv box and broadband off over night and tried again in the morning. No success. Issue is definitely with the sky tv box as we have working Internet on other devices. Only not connecting on the sky tv box.
This message was authored by Chodley This message was authored by: Chodley
Sky broadband or another ISP?
Barrymitchell22
Sky Broadband
Sky Broadband
hi @Barrymitchell22
Looks like you need a Sky Q booster to,position midway between your Qbox and your Sky router
yeah a booster might help
Maybe try the steps in post 7 here (and look at the link in 8 too)
https://helpforum.sky.com/t5/Sky-Q/Sky-q-box-not-linking-with-Wi-Fi/m-p/4504698#M618552
Barrymitchell22
The box is 1 metre away from the router. A booster is not required. The box is not working and I need to speak to someone in sky on the phone to resolve
Call them then? When you say 2 hours, was that just in a queue?
Did you try the steps I suggested? No one doubts it's the Q box at fault. Q boxes lose their wifi connection on a regular basis but those steps have worked for a lot of people. It's not like the electronics just stop working in 99% of cases, it's messed up configs.
We can eacalate to a chat service on here but not a voice call.
Why not use ethernet if it's so close?
