Discussion topic: My sky tv box wont connrct to sky wifi router
This message was authored by: Izzy+veronique+17
My sky tv box won't connect to my sky router
Re: My sky tv box wont connrct to sky wifi router
Hi @Izzy+veronique+17
Have you correctly carried out a Network reset on your Q box?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your Sky router.
You will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
This message was authored by: DealTracker
Hi!
Please tell us the error on the screen. Its hard for us to know what you are facing without any error.
