31
This discussion topic has been answered Discussion topic: My sky sports works perfectly but for TNT it’s says no satellite signal or at best pixelated picture
Find out more
Message posted on 26 Sep 2024 11:05 AM
Re: My sky sports works perfectly but for TNT it’s says no satellite signal or at best pixelated pic
@Vinny7 wrote:No it isn't solved
It is for the original problem that was posted at the time.
That doesn't stop others having issues. If you have done the power down reboot then it is time to get an engineer out to check dish alignment.
Was my post helpful or informative to you? Please give it a thumbs up/like.
If my post has solved your problem, great! Please click on "Mark as Answer" under it and share the love!
This message was authored by: westmeathwarrio
Message posted on 15 Jan 2025 09:11 PM
Re: Tnt sports poor reception this morning for Liverpool match All other channels working fine
Go to channel 868 on Sky , not channel 410.
@nolte wrote:What is your sky system? Sky q, sky+, sky glass, sky stream?
If sky q or sky+, there may have been just something interfering with the signal in its band
