Discussion topic: My sky remote control has stopped communicating with my tv and my Q box
This message was authored by: Pj02
I have just returned from holiday and my sky remote has stopped communicating with my tv and Qbox. I have replaced the batteries but the remote LED light does not light up when I press the ? Button
Re: My sky remote control has stopped communicating with my tv and my Q box
Hi @Pj02
First reboot your Q box.
Then when Q box is back up and running
Avatar for Pj02
Thanks for your kind reply. I had already tried your suggestion but I can not get the remote to do anything.
I ordered a new remote at 6pm and it arrived by 12 am and worked first time.
