Discussion topic: My sky que box is displaying the home page, but in the top left hand corner says no sign
Message posted on 11 Apr 2024 06:54 PM
The remote sky q box in the other room from the main box will only turn on manually. The home page comes up. In the top left hand corner there is a black box that says no signal
Message posted on 11 Apr 2024 07:03 PM
Re: My sky que box is displaying the home page, but in the top left hand corner says no sign
Hi @Tellytubby1
Reboot the mini as above.
