Discussion topic: My sky q mini box keeps loosing the picture
Message posted on 05 Jun 2023 08:00 PM
Message posted on 05 Jun 2023 08:02 PM
Re: My sky q mini box keeps loosing the picture
Hi @Matt+wiggy
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Message posted on 05 Jun 2023 08:05 PM
Cheers for that, I will give it a go now. I have 3 mini boxes and the other 2 are working fine. The one in question keeps going blank then coming back on every few minutes.
Message posted on 05 Jun 2023 08:21 PM
Tried rebooting as discussed but still doing the same.
Message posted on 05 Jun 2023 08:23 PM
Has anyone experienced this issue?
Message posted on 05 Jun 2023 08:25 PM
Hi @Matt+wiggy
Did you try the Network reset on the problem Mini?
Also you could try swapping the mini over with one of the others to see if the issue is due to the mini location.
Message posted on 05 Jun 2023 09:04 PM
I'm having same problem with one sky q box after it's been on for about an hour it starts pausing and losing signal have done all the usual stuff even updated it
