Discussion topic: My sky q mini box isnt working but my Sky Q main box is working
Message posted on 18 Oct 2024 06:51 PM
I've tried everything that I could The heading explains the issue/s. The main box is downstairs and the mini box is upstairs. I can't even get the manual button on the mini box to turn on. Ive changed the batteries on the remote control. Ive removed and replaced the SKY plug several times. No luck whatsoever
Message posted on 18 Oct 2024 08:05 PM
Re: My sky q mini box isnt working but my Sky Q main box is working
Hi @Mask+36
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Message posted on 19 Oct 2024 12:34 AM
Message posted on 19 Oct 2024 11:28 AM
I tried following the steps but I'm convinced its the Sky q minibox that needs replacing. I have tried everything. The lights on the minibox won't even come on. The button on the minibox wont respond either.
Can someone kindly advise how I get through to Sky to advise them. Is it their responsibility to replace it? I pay a high monthly subscription and I'm not getting what I ought to get.
Thanks in advance.
Message posted on 19 Oct 2024 11:39 AM
If you have tried those steps for the recovery procedure of your ask yea mini and it's not solved the problem, you can order a replacement online, either as described on the second page of the help link above or using the direct link here;
https://www.sky.com/help/articles/order-replacement-q-box
Message posted on 19 Oct 2024 12:01 PM
I made contact with Sky and I am going to be sent a new sky q minibox.
Thanks.
Message posted on 19 Oct 2024 12:04 PM
